Browse Forums General Discussion Re: Building Space Ratio (excluding garage space?) 11Nov 06, 2016 10:07 pm That will depend on your particular council. Some have the FSR rule and the ratio of floor area to site. What that means is that you have to consider the floor area of the ground floor plus the second floor added together to give you the total floor area. It is not just the footprint of your proposed house on the land which is what our local council goes by. Stewie Re: Building Space Ratio (excluding garage space?) 12Feb 19, 2023 11:40 pm Stewie D Quote: Depending what council an location you are in most DAs go way over the standard space ratio. That may be the case for a lot of the inner city councils but most in my experience farther out are a fair bit more restrictive. They also have to be careful regarding how many they let through that are over the usual FSR. This is an excerpt from a post that I have seen a few times. It is based on the regular info put out by Planning NSW on this site http://www.planning.nsw.gov.au/Policy-a ... -Circulars Quote: It appears that the magic number is an FSR of 0.55:1. Planning Circular PS 08-014 and PS 11-018 provide detail into why. Once there's a variation greater than 10%, it is to "be determined by full council (rather than general manager or nominated staff member)" and "any particular development standard are being regularly varied by a council may require review". So basically, once I go over 0.55:1 there's more work on Council's part and more visibility. And if they allow too many variations they may be forced by the state government to increase the FSR beyond 0.5:1. I have regularly got DA's through that are 5 -10% over the recommended max. FSR but usually only if there are good reasons for doing so and there are no other issues that the council could pull us up on. As OB123 says , a lot will depend on which actual council you are with. Stewie Hi , what are the good reasons for approving applications that go over the FSR under DA? Re: Building Space Ratio (excluding garage space?) 13Feb 20, 2023 7:26 pm There wouldn't be many if at all that I can think of unless you have a tiny block of land. It happened recently on a small block not far from here - probably around the 300 sq m size. All neighbouring properties would be in the 550 -650 sq m range but they were allowed to build a house with hardly any front or back garden. If you were thinking of applying with a FSR of say 60:1 and their law says 55:1 you may get it through by saying the floorplan is compacted as small as possible and it would be impossible to alter without seriously compromising the design. Site restrictions etc Stewie Re: Building Space Ratio (excluding garage space?) 14Feb 23, 2023 4:10 pm thanks so much! can I ask another question about CDC vs DA for FSR. CDC fsr excludes 18sqm for garage, where as DA does not include Garage on FSR? You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9963 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3587 |
