Browse Forums General Discussion 1 Oct 25, 2016 2:10 pm So i have been trying to figure out how wide this wall is in mm https://www.soundproofingcompany.com/so ... roof-wall/ (p.s i was looking at the table on steel framing that had a STC of 74) I got more questions aswell like 1. Do soundproof walls also provide Thermal Insulation? 2. If Soundproof walls DON'T provide thermal Insulation, then where should Thermal Insulation be installed? 3. In order to reduce the sound as much as possible, how thick should a soundproof floor(and walls, and MAYBE CEILING) be? 4. How thick is TOO THICK for soundproofing/Insulation? Re: Soundproof walls 2Oct 25, 2016 9:41 pm http://www.gyprock.com.au/Pages/Solutio ... Noise.aspx enjoy reading..... and yes the sound batts used provide both sound and thermal insulation. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11117 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11770 |
