Browse Forums General Discussion Re: Replacing Weep Holes with Brick Vents 2Oct 16, 2016 9:39 pm kitty1 Hi all. I just wondering if anyone knows if I would be able to cover up a weep hole and replace it a brick above with a brick vent? I am on a flat section level with the pavement and looking at my weep holes there are some lower than the rest with a series of them very low in one section making it hard to do a compliant concrete perimeter without it all being at different levels. which would look weird as well. No, you can't replace weep holes with vents. They are for different purposes. Weep holes have flashing that ensures that condensation on the inside of the bricks drains to the outside. Vents do not do this. Can you post a few photos? The description is a bit confusing. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7075 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5423 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11153 |
