Browse Forums General Discussion 1 Oct 16, 2016 5:15 pm Can anyone give me an idea of the best way to go about rendering my garage? I want to start off with just one wall (seen in photo below). It's 7.2m long and 2.35/2.05m high (dropping down in height about half way down). What's most commonly used in garages these days? I've heard about acrylic render - is this the way to go? I want a smooth finish that looks like normal plaster. What sort of cost would I be looking at per sq m to get it done? Thanks! Please note - the bricks are wire cut with deeper than normal joints. Also - what would look better - getting the wall done just up to the rear corner, or getting the small part of the back wall between the corner and door done as well (and possibly painting the door to match?). I also want to get the concrete floor painted too so any help with that would be welcome. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5240 |
