Browse Forums General Discussion 1 Oct 08, 2016 9:15 pm Hello and thank you for your time, I'm new to this site and found this through google search hoping some of you knowledgeable people may be able to help. I have an IKEA besta unit which I would like to wall mount, problem is the studs don't line up with the brackets. Unit is 1.8 meters long and it has 4 L shaped brackets at 600 apart, studs are 450 apart and to hang the unit in the center of the room the brackets miss every stud. Is there any way I can wall mount the unit? Sorry for the long post, thank you in advance If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 6096 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 34212 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 1327 |
