Browse Forums General Discussion 1 Oct 03, 2016 1:42 pm After changing washers on leaking shower taps, the hot water tap distributes lukewarm water now. The other room's shower and all the wash hand basins in the house have piping hot water. It is just the master bedroom shower which has changed from hot to warm water and I want hot water. Any ideas how to fix it? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13539 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
