Browse Forums General Discussion 1 Sep 08, 2016 10:41 am Hello, all, I am building house with Metricon at the moment ( near the completion of lock-up stage ). However, Metricon told me they made a terrible mistake with overshadowing plan and my house is 300mm higher at back corner and blocked the sun light to the neighbor. Metricon is preparing new design at the moment to be compliant with regulation. The possible solutions are A) cut off some eaves. B) redesign one or two bedrooms to be compliant. Since it is 100% Metricon fault and it changes the house what I want, I am entitled to ask for compensation from Metricon. The question is how much discount I should ask for. I don't want to give Metricon a number which is not realistic and won't happen. So I need input from everyone how much discount is reasonable. For example, 5% discount or something else. Re: How much compensation should I ask for 2Sep 08, 2016 1:28 pm IMO, see what they say when you ask them what they will offer for doing this to you. Redesigning the bedrooms doesn't sound ideal, the eaves solution may be better. You might be able to get them to include something that would normally be an upgrade rather than discount the price. Re: How much compensation should I ask for 3Sep 08, 2016 1:53 pm I will definitely ask for their offer. They most likely will come back with something like thousands dollar. Considering the inconvenience and hassle Metricon has caused to me ( I have been hassled by this terrible mistake for a couple of months and there is no sign when it will end ). Also cutting off the eaves will make the house look very ugly. I will definitely not sign on new design with thousands of dollar. However, I don't want to put myself in a situation that my proposed figure is not realistic and impossible to negotiate, How much compensation should I ask for 6Sep 08, 2016 5:48 pm Go to council and get current design approved
Fairly easy option and should take the same time Re: How much compensation should I ask for 7Sep 08, 2016 5:54 pm yhfg27 Hello, all, I am building house with Metricon at the moment ( near the completion of lock-up stage ). However, Metricon told me they made a terrible mistake with overshadowing plan and my house is 300mm higher at back corner and blocked the sun light to the neighbor. Metricon is preparing new design at the moment to be compliant with regulation. The possible solutions are A) cut off some eaves. B) redesign one or two bedrooms to be compliant. Since it is 100% Metricon fault and it changes the house what I want, I am entitled to ask for compensation from Metricon. The question is how much discount I should ask for. I don't want to give Metricon a number which is not realistic and won't happen. So I need input from everyone how much discount is reasonable. For example, 5% discount or something else. I'd get a legal representative involved to see what you are entitled to Re: How much compensation should I ask for 8Sep 08, 2016 8:51 pm If it was approved by council is it really you or your builders problem? Council will probably need to compensate your neighbours for their mistake but if you've got prior approval it would be a bit rough to reverse it now Re: How much compensation should I ask for 9Sep 09, 2016 10:55 am the house is at lock-up stage now. the building plan is endorsed by the Metricon's surveyor which is called GROUP FOUR. The problem was found near the end of lock-up stage. This problem has been put forward to council now. Metricon, GROUP FOUR and Council are discussing. Since all of these problems are caused by Metricon, how much compensation I should ask for? what would I do if Metricon refused to compensate? Re: How much compensation should I ask for 10Sep 09, 2016 11:06 am yhfg27 .....what would I do if Metricon refused to compensate? It's going to cost you a lot of time,stress & money in the civil courts. goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How much compensation should I ask for 11Sep 09, 2016 11:59 am There is option to make application to Building Appeals Board to allow the design to remain given construction has advanced so far. The appeal may or may not be successful but its worth a try. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How much compensation should I ask for 13Sep 09, 2016 3:03 pm building-expert There is option to make application to Building Appeals Board to allow the design to remain given construction has advanced so far. The appeal may or may not be successful but its worth a try. will it override the decision made by council? currently they are talking to council. not sure whether the appeal will override council's decision. Re: How much compensation should I ask for 15Sep 09, 2016 6:27 pm You are entitled to nothing at the moment till everything is confirmed Wait till councils decision Re: How much compensation should I ask for 16Sep 09, 2016 7:06 pm Gimme gimme gimme. Take a breath and wait to see what the council says. If it's the house you want that was originally designed, then push for the Appeal if it ends up not being in your favour. Otherwise you look like a money grubbing dbag. The longer it takes the more liquidated damages you claim at the end for going over contractual periods. Win win. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: How much compensation should I ask for 17Sep 12, 2016 11:14 am another question, what can I say or what I can do if Metricon does not want compensate? they caused so much trouble and stress on me, let alone the house does not look like what I want, massive delay since Aug ( I got a letter from Metricon saying my house was on hold since Aug 16). Re: How much compensation should I ask for 18Sep 12, 2016 1:30 pm yhfg27 another question, what can I say or what I can do if Metricon does not want compensate? they caused so much trouble and stress on me, let alone the house does not look like what I want, massive delay since Aug ( I got a letter from Metricon saying my house was on hold since Aug 16). I think you are trying to answer questions before situation has played out, wait and see. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How much compensation should I ask for 19Sep 14, 2016 5:55 pm building-expert yhfg27 another question, what can I say or what I can do if Metricon does not want compensate? they caused so much trouble and stress on me, let alone the house does not look like what I want, massive delay since Aug ( I got a letter from Metricon saying my house was on hold since Aug 16). I think you are trying to answer questions before situation has played out, wait and see. Speak to fair trading Re: How much compensation should I ask for 20Sep 15, 2016 8:34 am jackie_saliba building-expert yhfg27 another question, what can I say or what I can do if Metricon does not want compensate? they caused so much trouble and stress on me, let alone the house does not look like what I want, massive delay since Aug ( I got a letter from Metricon saying my house was on hold since Aug 16). I think you are trying to answer questions before situation has played out, wait and see. Speak to fair trading And say what? We're trying to point out its putting the cart before the horse. The response will be to wait out until a solution is offered, discuss/negotiate, then if not happy to contact them again. It is literally 100% a waste of time at this point. I'm not surprised some people have terrible experiences. Typically its people who stress and jump up and down because they've not followed a logical order to dealing with issues. "My frame is overhanging, I better get a lawyer involved" or " the paint job is poor, I'm going to go to vcat" Settle down people. Have an adult conversation, fact check the offered solutions, make a decision if you're happy with the offer, THEN go back and renegotiate. If that fails THEN escalate to the appropriate bodies/ get legal help. Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15013 Ardo That is so funny! I wonder how many people know who Larry Haun is these days. I have a couple of young guys we call Mo 1 & Mo 2 who run a crew of 6 boys and… 9 15417 7 11871 |
