Browse Forums General Discussion 1 Mar 17, 2018 6:27 pm I'm looking for advice about insulating a shed that is big enough for 3 cars, there are 2 roller doors, there is already a basic kitchenette that I would also be replacing at some point. I want to do this so that during summer I can put air con on in there and have people over. My house is not huge so I see this as a logical choice for extra living space. I won't be using it to store any vehicles as there is enough covered areas to house a couple of cars. I have had a couple of builders come out and look at what I want to do but have never received a quote from anyone. The walls are plain metal walls. Re: Insulating 3 car garage/shed 3Mar 18, 2018 3:56 pm The Inside I want to keep the roof area open. Ignore the contents in the area. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is one of the ends, the projector screen will be going back on the wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The back wall has power & data outlets and TVs will also be going back on this wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The other end has a bench along the enter end, although it is a nice and sturdy bench I'm happy for it to be removed if required. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The other wall has the 2 roller doors, a hinged door and the kitchenette. These are going to remain. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A closer look at the bench Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The outside Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front, with doors open Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Left Side Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Back (looking at putting a storage shed behind this one) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Right side Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front with the doors closed. Re: Insulating 3 car garage/shed 4Mar 18, 2018 7:58 pm Hi m4cc4s Thanks for the Photos I recommend you insulate the walls & ceiling Batten (600crts) out the frame and put up plasterboard? Here's a quick breakdown of Materials & Labour You can source the material prices online Guesstimate 6x9x3 Shed Volume 180m3 (No deductions made for content) Wall Surface Area 94m2 Ceiling Surface Area 56m2 Battens Steel Top Hate 180 l/m You may need to make deductions for Doors & Windows Materials R 3.5 Insulation Batts 10mm Plasterboard? Labour 1+1 Top Hat Battens, Insulate & line 2 people 2 weeks work Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulating 3 car garage/shed 5Jan 26, 2019 3:40 pm Here is a link to a pretty detailed video on insulating a garage, in Melbourne. Spray foam combined with conventional batts. https://www.youtube.com/watch?v=fJGYchSx5SY DIY, Home Maintenance & Repair Turning this into my DIY shed makeover. I had a brickie fix the back wall up and it's rock solid now. I'm into ripping down the inside ceiling that was installed and… 1 12490 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 8060 |
