Browse Forums General Discussion Re: Anticon Blanket for Colorbond roof - is it required? 5Sep 10, 2016 9:17 am It is not essential, but you'd be mad not to do it now. Doing it later will cost you an arm and a leg, as all the sheeting has to be removed to put the anticon blankets in place Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2251 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10532 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 20909 |
