Browse Forums General Discussion 1 Nov 16, 2006 8:04 pm NOTE:Part of the following is from www.floorbamboo.com
Hi there, Are you puzzling over the installation of bamboo flooring. Here I share some points with you. Hoep they will be of helpful for you.. 1)Sub floor: surface shall be clean, dry, smooth, and free of dirt, wax, oil, paint that would interfere with adhesive bond. 2)Color averaging: bamboo being natural material, the color and grain variation is considered normal. It is suggested that installer mix and use flooring from separate cartons to achieve optimum result. 3)Application: If the subfloor is wood, then bamboo floor can be either nailed down or glued down. But if the subfloor is concrete, bamboo floor can only be glued to it. Re: Installation Guide for Bamboo Flooring 2Nov 19, 2006 11:17 am Very good Tim,
we have a few interested people in here after Bamboo flooring. ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com DIY, Home Maintenance & Repair Thanks for your input. It is a skillion roof carrying both ceiling and roof loads. I didn't think of LVL so I will look at this option. I will be screwing timber into top… 2 3826 Hi Marko The best thing to do is to have a look at your contract and see how the variation clause is worded. We use the NSW Fair trading contract and the way that is… 1 1424 ![]() |
