Browse Forums General Discussion Re: Bricks under windows - concern 5Sep 04, 2016 6:48 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Bricks under windows - concern 7Sep 05, 2016 6:45 pm Aba121012 Thanks - The Sill bricks do not extend under the window frame, if you lift the black seal there is a gap between the bricks and the window framing. Is this ok? So long as rubber seal at bottom of windows completely covers brick it will be OK Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12759 Interesting. You have great clearance to damp proof course all the way around which is rare with so many cowboy landscapers and concreters. Is there sufficient fall… 2 2418 |
