Browse Forums General Discussion Re: Concrete path or pavers 2Aug 25, 2016 10:36 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path or pavers 4Aug 26, 2016 7:36 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path or pavers 8Aug 29, 2016 7:24 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path or pavers 10Aug 29, 2016 8:05 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path or pavers 12Aug 29, 2016 11:02 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path or pavers 14Aug 29, 2016 11:18 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path or pavers 15Aug 29, 2016 11:23 pm bg100 If you could point me towards the standards or building requirements that describe what needs to be done that would be appreciated. The BCA states: "3.1.2.3 Surface water drainage Surface water must be diverted away from Class 1 buildings as follows: (a) Slab-on-ground — finished ground level adjacent to buildings: the external finished surface surrounding the slab must be drained to move surface water away from the building and graded to give a slope of not less than (see Figure 3.1.2.2)— (i) 25 mm over the first 1 m from the building in low rainfall intensity areas for surfaces that are reasonably impermeable (such as concrete or clay paving); or (ii) 50 mm over the first 1 m from the building in any other case. (b) Slab-on-ground — finished slab heights: the height of the slab-on-ground above external finished surfaces must be not less than (see Figure 3.1.2.2)— (i) 100 mm above the finished ground level in low rainfall intensity areas or sandy, well-drained areas; or (ii) 50 mm above impermeable (paved or concreted areas) that slope away from the building in accordance with (a); or (iii) 150 mm in any other case." 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12875 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6549 Hi all Following the recent heavy rainfall in Sydney, I am keen on redirecting water away from the house's base as much as… 0 6802 |
