Browse Forums General Discussion 1 Aug 02, 2016 11:54 am Hi, We need to lay an AG pipe to drain away ground water (not storm water), but local Council said we can't connect it to the storm water pipe or drain it into the gutter, because possible contamination. Can anyone suggest other solutions? Thank you very much. Sunnie Re: AG Pipe connection 2Aug 02, 2016 12:41 pm The council is correct and doing stormwater work if you are not a licensed plumber qualified for that work is also illegal in most States. The surface water must first pass through a silt pit. Check AS 3500.3 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: AG Pipe connection 3Aug 02, 2016 12:54 pm Hi, Thanks for the message. The water needs to be drained away is not storm water, but water from under ground water table, not from roof gutters. If it can't be connected to storm water, where can they be connected? Many thanks Sunnie Re: AG Pipe connection 4Aug 02, 2016 1:23 pm It can be connected to the stormwater provided it first drains into a silt pit. The pit used is usually one that is already part of a surface drainage system already connected to stormwater. It comes under SUBSOIL DRAINAGE DESIGNS - DESIGN in AS 3500.3 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: AG Pipe connection 6Aug 02, 2016 4:15 pm This link will provide you with some more information about silt pits: http://anewhouse.com.au/2014/09/silt-pits/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. 3 48409 Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need… 0 4269 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 |
