Browse Forums General Discussion Re: Are these bricks *******? 23Aug 11, 2016 11:52 pm Howyagoing , , that's part of the problem ,not knowing , , good brickwork will be consistent with mortar been consistently the same, when you get different mortar gap thickness , bricky either cant or wont have the skil or care factor to do proper work. Re: Are these bricks *******? 29Aug 14, 2016 9:15 am Howyagoin Haha. If the downpipe is plumb, which it should be. Sight down the line of it and see how good the bricks are mate Agreed, the bricks especially from 1/2 to 2/3 the way up the wall are all over the place. They do look tidy though. Re: Are these bricks *******? 32Aug 18, 2016 10:17 pm Based on the photo, perpends are rubbish, internal corner could be better, but is harder to make neat. The articulation joint is too close to the wall should be on the other side of the window but could be a design requirement. Re: Are these bricks *******? 33Aug 19, 2016 9:07 am Alexxdavid Would that even be considered ok or not? These are external bricks seen from the inside. There will be render on the outside and internal bricks still left to be done on the inside. If youre in WA then yes. Look at other houses around you. And its being covered in render so it wont be seen. Re: Are these bricks *******? 35Aug 19, 2016 1:34 pm As I mentioned in a previous post, if the downpipe is plumb sight down the edge of it vertically and the perpends are all over the place. The perpends in general could be better separate from that area Are these bricks *******? 39Aug 21, 2016 10:34 am You are a muppet, joker. You show off your unsatisfactory brick photo, get schooled by not only me but a couple of others and yet, still get on here and make noise. Have a spell off the internet until you can offer something decent. Re: Are these bricks *******? 40Aug 21, 2016 1:25 pm 36 post hero no nothing , your the only mouth, , others couldn, t see, , this was done by a top bricky who teaches teacher's, even mortar , ,straight bricks, you cant see quality as , you base your crap on non brick work, ,fool like yourself exposes why some are taken by bad trades. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19158 |
