Browse Forums General Discussion 1 Jul 22, 2016 12:42 am hi new poster here had a water pipe burst in the ceiling and saturate carpet and stain the walls also blew chunk of cornice also noticed at floor level skirting board popped from wall been told thats from leaking shower adjacent to bedroom wall can someone verify this n wat is involved in repairing n removing mold which is present apparantly its been leaking somegime Re: leaking shower and mould 2Jul 22, 2016 10:50 am Cutting a hole in the wall behind the taps on the bedroom side and having a look is probably the best way of finding out. Patching a plasterboard wall is relatively easy to do afterwards. Stewie This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24148 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9578 |
