Browse Forums General Discussion 1 Jul 10, 2016 6:33 pm Guys, While we are discussing with one of the builder they mentioned retaining wall will be required towards rear of the property. Anyone can suggest why this would be required? The land is not flat and there is fall from rear towards front. Approx 1m fall I would say. Could this be reason for retaining wall? How much can it cost for such retaining wall for 14m wide lot? We are trying to do some budgets and hopefully the cost of retaining wall wont be too much. thanks, Looking to build a home in VIC. Land titled in November 2017. Construction started in February 2018. Double storey 37sq. Re: Retaining wall towards read of new build 2Jul 10, 2016 8:26 pm Builders usually level the site by cut and fill. As the back of the block is higher they will be planning to cut into it which is why you need a retaining wall to retain the garden/back fence. There may be additional foundation costs, which will depend on the site slope. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Retaining wall towards read of new build 3Jul 10, 2016 9:17 pm Hi Love guru you can do the retaining yourself if its at the rear and away from the building envelope You might also consider steel posts and rails spans 1.80m to 2.4m depending on soil classification M or S respectively Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs The plan is to demolisgh the home, earthworks to prepare for slab, and then removal of existing wall for a new one. Requires a DA unfortunatley as the new wall will be… 6 21694 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 1329 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 11072 |
