Browse Forums General Discussion 1 Jul 03, 2016 4:09 pm G'day, I have a 10 mt x 10 mt galvanised iron on timber shed. I want to add a Awning - Lean To extension at the back. The roof extension will be 2 mt. This will allow me to store timber etc. to keep dry. I would like to know the what size timber I will need for the uprights, would 100 x 100 be strong enough? How far apart should the posts be? What size timber for the beams. I live in the bush so I do not need approval. I would appreciate some help please. Perry Re: Adding a Awning to a shed 2Jul 04, 2016 10:01 pm I would build the lean to out of steel. The termite generally leave steel alone. 64mm square steel posts and 150x65 C sections for the rafters. Most Steel merchants can provide a design & supply service. They can also supply fixings flashings and gutters. If the lean to roof is flat use kliplock roofing sheets. They can be used down to 2 degrees pitch. Re: Adding a Awning to a shed 3Jul 05, 2016 6:41 am G'day Beetaloo, Thank you for your reply. I would prefer to use timber as I have a friend that can get treated hard wood cheap. How many posts would I need and how far apart. The fall would be an inch as I have a rain water down pipe going to a Tank. Cheers Perry Re: Adding a Awning to a shed 4Jul 05, 2016 9:53 am A 200 x 50mm MGP10 beam supported by 100 x 100mm posts @ 2400mm span will be all you need. Three 75 x 50 battens for the roofing and you are sweet. Just remember to use tie-downs and bolt the beam to the posts and the posts to stirrups on a concrete pad. It gets pretty windy up in Maryborough !
Edit : I should have added that for a span of 2000mm use 100 x 50mm MGP10 rafters @ 900m spacings. A lot of guys space them @ 1200mm but it's just harder to walk on a roof at that distance. Some speed bracing over the lot to stiffen it up wouldn't go astray either. Stewie Re: Adding a Awning to a shed 5Jul 05, 2016 12:07 pm G'day Stewie D Thank you for your reply. That is all I needed to know. I will order the material and my WIFE should have if finished in no time at all!!!!! Cheers Perry 4 14294 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
