Browse Forums General Discussion Re: Gas and water pipes in ceilings 2Jun 26, 2016 3:33 am Yes but you need to ask a plumber to do it. The only possible problem would be a (probable) minor negative alteration to the hydraulic units calculation. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gas and water pipes in ceilings 3Jun 26, 2016 2:51 pm SaveH2O Yes but you need to ask a plumber to do it. The only possible problem would be a (probable) minor negative alteration to the hydraulic units calculation. I take my hat off to you Save H20, there is nothing that you don't know about water. We are lucky to have you on the forum. Thanks. Re: Gas and water pipes in ceilings 4Jun 27, 2016 1:55 pm The only issue that I could see that isn't a technical issue, is that your cold water could become a hot water supply on summer days. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Gas and water pipes in ceilings 5Jun 27, 2016 6:04 pm The Plumbing Regulations 2008 state: “Drinking water that is not intentionally heated must be delivered at a temperature of less than 40 degrees Celsius”. This can be difficult to achieve at all times when insulated water pipes are attached to beams but the installation itself is not prohibited. A plumber needs to do it and if he thinks that it won't comply because of ambient heat issues if the roof for example does not have Sisalation or because of the climate, he won't do it. The other issue is the increased friction losses to end fixtures due to additional pipe lengths but this rarely broaches compliance because the regulations only require the end fixture to have a minimum 50 kPa pressure. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10815 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20229 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39715 |
