Browse Forums General Discussion 1 May 01, 2016 5:00 pm We are currently building our first home and have chosen river gum beige as the window colour as we were told that we could match it to the fascia as its a colorbond colour... i was told wrong. So we had to choose another color bond standard color for the fascia as the windows had already been made - we choose Dune. Now we have to choose a render feature colour for the front of our house.. could any body help with suggesting a colour? we have Burnley bricks and a bush cherry roller door with monument color bond roof and gutters. Thanks S Re: Render advice needed 2May 05, 2016 8:25 pm I think Colorbond Paperbark would be a closer match to River Gum Beige. You could then have your render in any colour since your bricks/garage combo is quite versatile. I would probably pick something in the beige/grey-beige/grey sort of colours. If you were to keep Colorbond Dune you could use that as your render colour so that you don't end up introducing another colour since (apart from your bricks) you already have four different colours on your facade. [sneakersss] Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18298 |
