Browse Forums General Discussion 1 Apr 22, 2016 6:34 pm Hi I Just wondering if you can post me a photo of how your washing machine drain hose is attached to drain out. Only interested in top loader machines set up please. We are having some hook up issues and need to work out solution. Many thanks. Re: Laundry Tub Help Please 2Apr 22, 2016 7:07 pm Can you explain the issue your facing? My build with FHBD viewtopic.php?f=31&t=78344 Re: Laundry Tub Help Please 3Apr 22, 2016 10:31 pm The Laundry setup supplied by the builder does not allow for draining of the washing machine... so need to see what other builders supply. Re: Laundry Tub Help Please 4Apr 23, 2016 10:06 pm You will need to run the drain hose through the side of the cabinet and clamp it onto the inlet nipple of the trap below your trough My build with FHBD viewtopic.php?f=31&t=78344 Re: Laundry Tub Help Please 5Apr 23, 2016 10:10 pm Also, make sure you drill out the inlet nipple of the trap first as it will be sealed with a thin piece of plastic! My build with FHBD viewtopic.php?f=31&t=78344 Re: Laundry Tub Help Please 7Apr 27, 2016 1:11 am My builder at my request is doing a hidden outlet in the cabinet as described above. Because the washer and dryer are built in we wanted drainage concealed. Cheers Mark Re: Laundry Tub Help Please 8Apr 27, 2016 9:26 am But - didn't the house/sink have a draining point ? Or am I missing the point ? Re: Laundry Tub Help Please 9Apr 27, 2016 10:16 am My front loading washing machine is at the opposite end of the laundry from the sink with built in cupboards between. A set of taps is installed within the broom cupboard next to the washing machine to supply water to the machine and a flexible hose run through the backs of the cupboards to connect to the waste pipe under the sink at the opposite end of the laundry. The requirement is for a waterstop to be installed to the entries of the room, (a small aluminum 'L' angle to retain the water to within the room) can't see if they have… 1 2154 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 12498 Agreed. I just found out today the certifier has not given the final sign off. 2 4135 |
