If you look here arcachon
http://www.steel.com.au/products/coated ... sification
Stewie
Browse Forums General Discussion Re: Colorbond roof 22Jun 27, 2016 1:48 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Colorbond roof 23Jun 27, 2016 2:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Colorbond roof 25Jun 27, 2016 9:30 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Colorbond roof 29Jun 29, 2016 8:46 am Quote: Ask any tradie who has to climb onto a roof or into a roof space - certainly noticeable difference. I can vouch for that. Years ago I did a major reno and extension not far from here and after I'd finished they asked me to create a storage attic in the roof space. It was January and a pretty hot summer but I was waiting to get the go ahead for another job so said OK. We climbed up in the roof space and couldn't believe how hot it was up there. It was a dark coloured tile on the roof, really old sarking that had numerous holes in it and just stifling. The next day i bought my thermometer from home and hung it from one of the rafters. 52ºC. We ended up taking half a dozen tiles off the roof and cut a hole in the sarking to allow for a bit of ventilation. It was still a bugger of a job but bearable. Stewie Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10209 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18565 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2880 |
