Browse Forums General Discussion 1 Mar 19, 2016 10:35 am hey all. I'm looking to build my own garden shed as i can't find one priced correct that suits my needs... i wanted to run my method / material past everybody to make sure i'm on track Concrete slab frame to sit on the slab (or best to use stirrips?) treated pine frame one of my questions is can i screw my outside corrugated sheeting (or colourbond.. haven't decided) directly into the treated pine, or should i put some FC sheeting between the frame and the sheeting? might have some more questions throughout appreciate your feedback. Re: building a garden shed.... 2Mar 21, 2016 7:28 am Bolt your bottom plate down directly to the slab with Dynabolts or similar. No need for any other fixing down like stirrups or when you pour the slab leave reo rods poking up 150-200mm. When you put your bottom plate down, drill a 10mm hole where the rods are and slide the plate into position. Then bend the rod over. If you have your timber frame just past the outside of the slab a few mm, you can run your sheeting down past the slab 50mm or thereabouts so water runs off. Some speed bracing to the walls and roof frame will keep your shed straight as well. Fix the sheets directly to the top plate, to a mid row of nogs and to the bottom plate. Sarking the walls is optional but I'd do the roof to prevent condensation. Stewie Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5404 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3423 |
