Browse Forums General Discussion Re: Alarm Keypad - where did you place it? 3Mar 16, 2016 3:28 pm Just inside the hall near the door from the garage. We will use that way more than the front door. Re: Alarm Keypad - where did you place it? 4Mar 16, 2016 5:16 pm I would place it near the entrance you use the most, about 10 seconds away from the entrance and out of direct sight from outside the house. Most alarms have a configurable entry delay or have a 30-45 second entry delay before a code has to be entered (or they go off). Give yourself the ability to enter/reenter the code two or three times and you should be right (the wireless key will decide to stop working at the most inopportune time). Re: Alarm Keypad - where did you place it? 5Mar 16, 2016 8:19 pm The Alarm we just got pre-wired in has a garage door open/close and an alarm on/off button of the alarm fob. So we put the key pad near the front door. This was from advice from the alarm people. Re: Alarm Keypad - where did you place it? 6May 10, 2016 11:49 am You can put two Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 11268 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 14388 |
