Browse Forums General Discussion 1 Mar 07, 2016 6:36 am I was advised it's 5 years warranty from Metricon, if anything with internal wiring is screwed? In my case , all data sockets no longer working so I assume something to do with internal wiring. Hills hub is working fine in the garage. Re: Data wiring warranty - Metricon 2Mar 07, 2016 9:20 am All your data sockets would terminate back to a central location. Are you sure it's the Hills hub? How many data points do you have? For all of them to fail that would mean each individual cable needs to fail. Check for rats\mice if you're certain the hardware is ok, they may have chewed your cables. Re: Data wiring warranty - Metricon 3Mar 07, 2016 10:07 am Gunna All your data sockets would terminate back to a central location. Are you sure it's the Hills hub? How many data points do you have? For all of them to fail that would mean each individual cable needs to fail. Check for rats\mice if you're certain the hardware is ok, they may have chewed your cables. I'm sure the issue is not with the box in the garage, as at the moment, I have it connected directly to the wireless router and it works fine. But as this is not ideal, I prefer to connect the wireless router to the data sockets inside the house (which was the original setting) until they were broken. So back to the original question: I was advised it's 5 years warranty from Metricon, if anything with internal wiring is screwed? do you know if this is accurate? I have no sign of mice nor rats in my premise and FTA, Foxtel & Phone are all working fine. I wouldn't think the rats/mice prefer to eat the data cable because it's tastier. Re: Data wiring warranty - Metricon 5May 10, 2016 10:52 am Yeah, as above floor said, call them Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20650 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13845 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10738 |
