Browse Forums General Discussion 1 Jul 25, 2008 11:14 am Hi
We're just finishing off engineering for our house. We were going to have a 5m wide double garage door, but now it looks like it may have to be 4.5m for structural reasons. The garage itself is 6m wide. Will the 4.5m door be wide enough? How wide are your garage doors? Thanks Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: How many metres wide is your double garage door? 2Jul 25, 2008 11:18 am Door is 4.93m wide, garage inside is 6.24m
4.5m seems a bit skinny - is the garage a bit longer so that you'll have enough room to drive in and then veer left or right? After 4 years - we're in! Re: How many metres wide is your double garage door? 3Jul 25, 2008 11:26 am stonecutter1309 Door is 4.93m wide, garage inside is 6.24m 4.5m seems a bit skinny - is the garage a bit longer so that you'll have enough room to drive in and then veer left or right? The garage is 12m long! But the rear part is supposed to be a workshop and store. We might be able to extend the door to 4.9m but that means that there will only be 200mm between the right hand end of the door and the right hand wall and so I was wondering whether it was worth expanding it..... Thanks Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: How many metres wide is your double garage door? 4Jul 25, 2008 11:28 am Commodore or Falcon (large sedan) is 1900 mm wide excluding mirrors.
Mazda 6 or Subaru Outback (mid sized sedan) is 1750 to 1800 mm wide excluding mirrors. Mazda 3 or Hyundai Getz (small car) is 1650 to 1770 mm excluding mirrors. Add 150 mm x 2 sides x 2 cars for side for mirrors then getting two cars in is a bit squeezy. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: How many metres wide is your double garage door? 5Jul 25, 2008 11:35 am to_do_list Commodore or Falcon (large sedan) is 1900 mm wide excluding mirrors. Mazda 6 or Subaru Outback (mid sized sedan) is 1750 to 1800 mm wide excluding mirrors. Mazda 3 or Hyundai Getz (small car) is 1650 to 1770 mm excluding mirrors. Add 150 mm x 2 sides x 2 cars for side for mirrors then getting two cars in is a bit squeezy. Yes I measured the cars but didn't think I would be driving both in simultaneously.... hmmmmm not sure what to do. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: How many metres wide is your double garage door? 6Jul 25, 2008 11:35 am The Dynamic Duo Hi We're just finishing off engineering for our house. We were going to have a 5m wide double garage door, but now it looks like it may have to be 4.5m for structural reasons. The garage itself is 6m wide. Will the 4.5m door be wide enough? How wide are your garage doors? Thanks Simon There is no 'standard width' as such for double garage doors. They can be made any width to over 6 metres. However, the standard width for single garages is generally considered to be 2400mm. So one could assume that a standard double width should be 4800mm. Having said that our double garage door is 4680mm. I guess you could try putting a couple of posts on the ground 4.5m apart and see how you go. Re: How many metres wide is your double garage door? 7Jul 25, 2008 11:36 am TDD - I think the extra 40cm in the garage door might be worth it if you don't want to sacrifice any of the length. After 4 years - we're in! Re: How many metres wide is your double garage door? 8Jul 25, 2008 11:50 am The Dynamic Duo to_do_list Commodore or Falcon (large sedan) is 1900 mm wide excluding mirrors. Mazda 6 or Subaru Outback (mid sized sedan) is 1750 to 1800 mm wide excluding mirrors. Mazda 3 or Hyundai Getz (small car) is 1650 to 1770 mm excluding mirrors. Add 150 mm x 2 sides x 2 cars for side for mirrors then getting two cars in is a bit squeezy. Yes I measured the cars but didn't think I would be driving both in simultaneously.... hmmmmm not sure what to do. Simon It's not about synchornised parking.... ....generally you back straight into a garage...as you need to be able to get the mirrors to pass each other, and then you need to be able to open the doors. Not sure if you have kids but getting them into a car - baby seat or booster and putting on there seat belts without opening the door fully is a pain in the a*se. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: How many metres wide is your double garage door? 9Jul 25, 2008 12:01 pm to_do_list Not sure if you have kids but getting them into a car - baby seat or booster and putting on there seat belts without opening the door fully is a pain in the a*se. Yes I agree. The thing is though, the garage is 6m wide, but due to engineering requirements we will have to spend some money if we want the door to be more than 4.5m wide. I think tomorrow I will do what floorit suggested and mark out the garage with sticks, and then drive both cars in and see how it feels. Thanks everybody for the help. Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: How many metres wide is your double garage door? 10Jul 25, 2008 12:27 pm The likelyhood of 2 cars passing thru at the same time is low....
If it costs more to upgrade/extend I would live with it! Re: How many metres wide is your double garage door? 12Jul 25, 2008 5:08 pm Our double door is 4.8m wide and both of the single doors are 2.4m wide - we are lucky however to be having a garage that measures 13.41m by 10.24m. I would be erring on the side of generosity - TDL, I agree with you. I have a 3yr old plus a 1yr old - new safety laws mean that these kids - plus any more in the future - will have to be in booster / safety seats until they are 8yrs old so I would want the maximum amount of space to be able to move around the vehicle (also doesn't help that DH drives and F150 and me an Explorer ) Re: How many metres wide is your double garage door? 13Jul 25, 2008 7:29 pm If the garage is constructed from brick then the opening size would be made to brick modules. Generally a double opening would be 4810 & a single 2410. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: How many metres wide is your double garage door? 14Jul 25, 2008 7:35 pm My design has a 4.78 m door and a 5.82 m wide garage.
I think the garage door width is good, but would have liked an extra 0.3 m garage width. How much more is a slightly wider door. I think 4.8 m is a good width, so maybe something between your original figure and the new figure would be just right. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: How many metres wide is your double garage door? 15Jul 25, 2008 8:26 pm ausdesign If the garage is constructed from brick then the opening size would be made to brick modules. Generally a double opening would be 4810 & a single 2410. It's not brick, it's ICF, so it can be any width. Going up to the block first thing tomorrow morning to peg out a garage plan and practice driving into it! Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Re: How many metres wide is your double garage door? 16Jul 25, 2008 8:51 pm The Dynamic Duo Going up to the block first thing tomorrow morning to peg out a garage plan and practice driving into it! Simon LOL...this should be fun to watch!!! Good luck with your driving err parking skills For what its worth our garage door is 5.2m and the garage is 11.8m wide, we easily get two family cars without the need to worry about hitting anything. Re: How many metres wide is your double garage door? 17Jul 25, 2008 8:56 pm The Dynamic Duo Going up to the block first thing tomorrow morning to peg out a garage plan and practice driving into it! The forum demands photographic proof of said experiment...... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: How many metres wide is your double garage door? 18Jul 26, 2008 9:02 am to_do_list The Dynamic Duo Going up to the block first thing tomorrow morning to peg out a garage plan and practice driving into it! The forum demands photographic proof of said experiment...... I second that!! Paula Re: How many metres wide is your double garage door? 19Aug 10, 2008 9:02 pm kiwi056 The Dynamic Duo Going up to the block first thing tomorrow morning to peg out a garage plan and practice driving into it! Simon LOL...this should be fun to watch!!! Good luck with your driving err parking skills For what its worth our garage door is 5.2m and the garage is 11.8m wide, we easily get two family cars without the need to worry about hitting anything. 11.8m wide? Re: How many metres wide is your double garage door? 20Aug 11, 2008 7:45 am yes I wondered about that! I think I would have no problem parking 2 cars side by side in that situation.....
Simon Building an architect designed home out of Insulated Concrete Forms on acreage in semi-rural SE Melbourne. Developer approval obtained, engineering complete, getting quotes Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 Any joinery expert, please advise. Is it possible to add drawers in this 750mm wide joinery in a small bathroom. My builder told its not possible… 0 536 |
