Browse Forums General Discussion Re: Garage Extending costs 13Mar 15, 2016 9:25 pm At least that is an improvement good luck with the build Our Build Thread - JG king Memphis If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5507 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1690 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7984 |
