Browse Forums General Discussion 1 Feb 20, 2016 7:40 pm I posted this in another forum topic but it might be more appropriate here. My property has an angled roof line and high loft windows. The solar hot water system has just been installed but they have put it DIRECTLY in front of one of these high windows which seems crazy since it blocks it!! Is there a way around this issue so it doesnt block the window. I dont understand how building plans can be approved like this. Why build an angled roof with beautify sunshine coming through the high windows only to block it with a monster hot water system. Re: Where to put the Solar Hot Water System 2Feb 21, 2016 9:04 am Didn't you get a chance to say where it went ? Everything can be changed - but it might cost. It should have been shown on your plans. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14074 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1353 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
