Browse Forums General Discussion 1 Feb 15, 2016 3:11 pm I have just carried out a Garage Conversion by replacing the roller door and installing two Glass sliding doors and a wall dividing them approx 1.5meters wide. The issue I have is the building certifier has requested I put flashing above the sliding doors and run it the full length of the garage opening. Their currently is a beam running across the garage span above the doors under the eves approx 250mm wide. The issue I have is I'm not sure what to use and how to install the flashing can anyone assist please. Matt Re: Garage Conversion 2Feb 17, 2016 5:01 am You could probably get a flashing bent up from a roofing company and silicone and pop rivet it the the window and steel beam. Do you have a photos you can share? Might be easier to point u in the right direction if we can see it. Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 10924 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7736 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 3489 |
