Browse Forums General Discussion 1 Feb 09, 2016 7:43 am The NSW govt is considering relaxing laws concerning secondary dwellings /granny flats specifically allowing the current max floor area of 60 sq m to be raised to 75 sq m after some research showing that a lot of units of this size were only one bedroom. Raising the floor area would allow two bedrooms and still have a reasonable living area. Now where it becomes interesting is that these proposed changes will be only allowed if the secondary dwelling is "only when constructed within an existing dwelling house". If you are proposing to build a secondary dwelling in your backyard you will still be limited to 60 sq m. http://yoursaywarringah.com.au/planning ... ased-floor This is from our local council but I would suspect others in NSW will propose the same changes if they haven't already. I'd imagine other states will do likewise. Stewie Re: Changes to Granny Flats ( secondary dwellings ) floor ar 2Feb 12, 2016 6:50 pm Thanks Stewie, that's good to know. I have spent some time considering granny flat designs, & found 60 sqm to be a tight squeeze for a 2 bedroom place. Requiring ingenious "tiny house" design features. 75 sqm should make things a bit easier. Re: Changes to Granny Flats ( secondary dwellings ) floor ar 4Feb 13, 2016 1:42 pm Stewie D The NSW govt is considering relaxing laws concerning secondary dwellings /granny flats specifically allowing the current max floor area of 60 sq m to be raised to 75 sq m after some research showing that a lot of units of this size were only one bedroom. Raising the floor area would allow two bedrooms and still have a reasonable living area. Now where it becomes interesting is that these proposed changes will be only allowed if the secondary dwelling is "only when constructed within an existing dwelling house". If you are proposing to build a secondary dwelling in your backyard you will still be limited to 60 sq m. http://yoursaywarringah.com.au/planning ... ased-floor This is from our local council but I would suspect others in NSW will propose the same changes if they haven't already. I'd imagine other states will do likewise. Stewie It looks like this is just an application by a single Council to vary conditions for that Council, so not a big change to NSW. I can see it being challenging fitting the extra dwelling inside an existing building envelope. Unless it is an existing two storey? Re: Changes to Granny Flats ( secondary dwellings ) floor ar 5Feb 13, 2016 5:29 pm Thin end of the wedge joynz ! Once one council has it approved ( and this would have the tacit support from the NSW govt relating to squeezing more people into medium density housing without contributing to urban sprawl ), then it has set a precedent and other councils will undoubtably follow suit. Quote: I can see it being challenging fitting the extra dwelling inside an existing building envelope. Unless it is an existing two storey? The way I understand it is that if you have an existing house and can fit it into your building envelope as you say then you will be able to do this. I think this will apply for new builds as well where once again if you can do it under the proposed building envelope you should be able to do this too. For others that can't do this then you will be limited to doing the standard Granny Flat thing of having a separate dwelling on your property but limited to the existing floor size of 60 sq m max. Stewie Re: Changes to Granny Flats ( secondary dwellings ) floor ar 6Apr 02, 2016 1:59 pm Amend the Residential Planning rules to allow up to 60m2 permanent secondary dwellings to be built behind existing homes without planning approval and for use OR rental by parties unrelated to the main dwelling. support Victoria to change the law. please sign the Petitioning below: https://www.change.org/p/the-hon-richar ... m=copylink CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4106 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13881 |
