Browse Forums General Discussion 1 Feb 08, 2016 1:35 pm Hi all, In a 37 sqm, 30 year old unit, I would like the old tiles lifted (they are 30 years old too), and the concrete polished. There appears to be a 2mm slope on the southern corner of the floor. Given the slopage, this might suggest cracks in the cement slab? and I guess I am stuck with the slope if the slab is polished it doesn't get re-levelled with the grinding? I am wondering if it is worth getting the tiles lifted and the concrete polished. We have no idea what the concrete slab has in it. All input greatly appreciated. Re: Polished concrete in 30 year old unit 2Feb 08, 2016 3:34 pm only if you upgrade the rest of the unit to match the floor, otherwise it will look out of place. Its poor likelihood that the concrete underneath is of a quality where the polish will look great. 2mm slope could be accounted for in the grinding, but if you are after a particular look the concrete under the tile wont give, consider pangea polished concrete veneer. This would take care of your levels too. Pangea can also be laid right over tiles, so you save on demo and disposal aswell Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: Polished concrete in 30 year old unit 4Feb 08, 2016 8:50 pm Hi threerivers Are you able to get hold of the original engineering drawings to check the area of steel that was allowed for shrinkage control cracking in the original design? This will assist you in choosing which was to proceed Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10208 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36939 |
