Browse Forums General Discussion 1 Feb 02, 2016 10:01 pm Hi all Can anyone suggest what cable thickness is appropriate for these new 12v lights I will be setting up? I have a 12v LED driver that plugs into the mains. Output is 100w, 8 A max. Connected will be 4 LED strip lights - each is 12v, 25W. Each light will be on a separate cable, no more than 6m in length. What is the right cable thickness? 1.3mm, 2.5mm something else? Many thanks. Re: Cable size for 12v LED lights 2Feb 08, 2016 8:06 pm 1.5mm figure 8 cable will be fine for your application. each 'circuit' or strip light will have its own feed from the transformer. Re: Cable size for 12v LED lights 3Feb 12, 2016 1:20 pm I have done 120 watt led with 1.3mm thickness and it is still working good So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23025 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7507 |
