Browse Forums General Discussion 1 Jan 19, 2016 8:14 am Hi everyone, Just going over our final custom plans and making any changes while we still can. We have a front timber post on our facade as below, our drawings say it is 125 x 125 size post. I am wondering whether this is the right size as I don't want it looking not substantial enough. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I was hoping for a look similar to this pic I found on here some time ago. Would this be 125 x 125 or larger?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: What size do you think this exterior timber post is? 2Jan 19, 2016 10:00 am I would say that a 125mm square post may look a bit undersized and not much bigger than a standard fence post. I would be taking a guess but the example in the image supplied would be at least 200mm square, could even be more (I have used the bricks behind as a guide... standard brick length is 230mm, post looks similar width give or take a bit of distance between post and wall). You want this to be a feature and not look like a small dingy post holding up the portico. Good luck Re: What size do you think this exterior timber post is? 5Jan 19, 2016 6:38 pm 125x125 would be very thin. Ours was 160x160 and felt that was to small so we upgraded to 190x190. I have also made sure they will do a t-bone bottom so it looks neater. If you want an idea of 125x125, just draw the square on a piece of paper and you will see how small that is. ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 Re: What size do you think this exterior timber post is? 6Mar 30, 2016 12:19 pm shellby 125x125 would be very thin. Ours was 160x160 and felt that was to small so we upgraded to 190x190. I have also made sure they will do a t-bone bottom so it looks neater. If you want an idea of 125x125, just draw the square on a piece of paper and you will see how small that is. Hi, can I ask what a t-bone bottom is? I don't like the look of the metal post showing at the bottom of the timber but don't know what other options there are. Thanks Re: What size do you think this exterior timber post is? 7Mar 30, 2016 8:19 pm Our posts near the entrance of our new build are 190x190 and we are very happy with them. They look quite thick but we love the look. Re: What size do you think this exterior timber post is? 8Mar 31, 2016 6:20 am Re: What size do you think this exterior timber post is? 9Mar 31, 2016 7:20 am Love your house MrBee! It's fairly similar to how I'm hoping ours will look. What colour is your render and window frames if you don't mind me asking? Re: What size do you think this exterior timber post is? 10Mar 31, 2016 10:45 am scottdreams88 Love your house MrBee! It's fairly similar to how I'm hoping ours will look. What colour is your render and window frames if you don't mind me asking? thanks mate, surfmist acrylic render and ultra silver windows from dowell... do you have a build thread to check out your place? Re: What size do you think this exterior timber post is? 11Mar 31, 2016 1:18 pm We havent got around to it as yet... We're at bricking stage so I wonder if its worth it now? Re: What size do you think this exterior timber post is? 12Mar 31, 2016 2:23 pm scottdreams88 We havent got around to it as yet... We're at bricking stage so I wonder if its worth it now? Always good to look at what others are doing etc I love reading all the build threads Re: What size do you think this exterior timber post is? 13Mar 31, 2016 9:36 pm Sorry its called a T-Blade post support. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Basically the support goes inside the post and then screw into it. ~Shellby~ GJ Bridgewater 203 11/3/2016 - Site Work Started 29/9/2016 - Handover 142 Work Days 6 Work Days Over https://forum.homeone.com.au/viewtopic.php?f=31&t=80174 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6631 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10213 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 |
