Browse Forums General Discussion 1 Jan 07, 2016 11:09 am Does anyone know any tips to prevent the glass from slipping down over time? Every a couple of months, I have to loosen the clamps to one of the panel on the balcony and prop it back up before tightening it. Doesn't happen to any of the indoor panels along the stairs and void. Re: Glass Balustrades 2Jan 11, 2016 8:27 pm Hi pongie, Sounds like a faulty clamp if it is the same panel each time. In any event you should ring the manufacturer I strongly advise. Grease may be a factor but doesn't sound like it. Also please take great care if the balcony floor level is far above the ground. Re: Glass Balustrades 3Feb 01, 2016 11:12 am I'll have to contact my builder then, no idea who is the manufacturer of the clamps. It is on the first floor, so I try and not to loosen the clamps too much (in case the glass panel falls off), just enough to prop it back up and tightened. It started happening to another panel on the balcony too now. Perhaps it's weather related? Balcony is exposed Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39045 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12390 |
