Browse Forums General Discussion 1 Jan 05, 2016 11:26 am Hi all A liitle assistance please. What do you reckon would be a reasonable price to supply/install ducting/flue/cowl to an existing exhaust fan so it vents out through the Colorbond roof instead of into the roof cavity? Appreciate any advice as I have two quotes wildly different. Re: Plumbing exhaust fans out through Colorbond roof 2Jan 05, 2016 9:13 pm Materials will be approx $60 plus 30 mins labour so I would be expecting to pay somewhere around the $200 mark My build with FHBD viewtopic.php?f=31&t=78344 Re: Plumbing exhaust fans out through Colorbond roof 3Jan 05, 2016 9:18 pm Althom Hi all A liitle assistance please. What do you reckon would be a reasonable price to supply/install ducting/flue/cowl to an existing exhaust fan so it vents out through the Colorbond roof instead of into the roof cavity? Appreciate any advice as I have two quotes wildly different. Where are you located and what were you quoted? Also are you flexible with timing or is it a rush job? Re: Plumbing exhaust fans out through Colorbond roof 5Jan 06, 2016 9:35 pm $1500!!! He must be having a lend My build with FHBD viewtopic.php?f=31&t=78344 Re: Plumbing exhaust fans out through Colorbond roof 9Jan 09, 2016 2:10 pm We vented ours outside via the eaves, have you thought of that option? might be cheaper. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: Plumbing exhaust fans out through Colorbond roof 10Jan 09, 2016 7:42 pm The one price I got for going out through the roof was fine. The only confusion was one quote at about what previous posters had estimated and one at +$1500. I didn't want to go cheap if I was going to get a cheap job. Turns out the cheaper quote was on the money and the clowns wanting over $1500 were just trying it on. In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 5363 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 5285 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 3686 |
