Browse Forums General Discussion 1 Jan 02, 2016 5:50 pm Without going into too much detail we're stuck with this gap between our fence and retaining wall (60cm wide, retaining wall is 80cm in height). http://imgur.com/GLboSM5 Ideally we would like to fill in the gap so it's not a danger hazard (kids falling in etc.), but we're short of ideas on how to fill it out. What would you do with this space? Thanks in advance! Re: WWYD with this space? Looking for ideas 2Jan 02, 2016 6:19 pm Maybe line the fence and block the end off with marine ply or fibro or anything that won't cop too much from the weather, line the ground with builders plastic, 100 - 200mm of gravel for drainage, then fill and make into a garden? Either that or get some 600 - 800mm high pot plants and sit them there? Could get expensive. A person needs to be licensed to offer financial advice. Surely the accountant you use would have been chosen for his/her expertise in this field. Have you asked your… 1 6733 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 |
