Browse Forums General Discussion Re: Single story floorplan 18m (w) x 12m (d) 2Dec 19, 2015 8:45 am Check out the various builders sites, they will give you the dimensions. Depending on which state you are in, some good ones to start with Carlisle, Metricon, Porter Davis, Burbank, Simmonds, etc. Re: Single story floorplan 18m (w) x 12m (d) 4Dec 19, 2015 10:53 am Those are fairly awkward and unusual dimensions, so you may need to customise a design to suit your block. A lot of builders regularly do this. You may be able to take something that's more a 12m wide x 18m deep, and turn it sideways, then moving the entry, rotating the garage etc. Turning the common layouts sideways I can see you swapping the entry and bathroom, and ending up with with a garage at one end with the master bedroom behind it, and then an entrance next to the garage and other bedrooms along the other side of it. That leaves the back of the house behind the bedrooms for the living area. But then the design choice will also be subject to the direction of North relative to the block. Single story floorplan 18m (w) x 12m (d) 6Dec 20, 2015 11:39 am I am building a custom build for corner block. Metricon were not flexible with adjusting any of their layouts to suit my requirements so I would not recommend them. You will have to find a builder that is flexible in doing a custom build for you on one of their layouts. Have a look at my plan and see what you think. viewtopic.php?t=81011 Build thread viewtopic.php?f=31&t=81011 Re: Single story floorplan 18m (w) x 12m (d) 7Dec 20, 2015 1:21 pm Charley I am building a custom build for corner block. Metricon were not flexible with adjusting any of their layouts to suit my requirements so I would not recommend them. You will have to find a builder that is flexible in doing a custom build for you on one of their layouts. Have a look at my plan and see what you think. viewtopic.php?t=81011 Looks interesting. Do you mind me asking cost /m2 and builder. Re: Single story floorplan 18m (w) x 12m (d) 8Dec 20, 2015 1:21 pm Charley I am building a custom build for corner block. Metricon were not flexible with adjusting any of their layouts to suit my requirements so I would not recommend them. You will have to find a builder that is flexible in doing a custom build for you on one of their layouts. Have a look at my plan and see what you think. viewtopic.php?t=81011 Looks interesting. Do you mind me asking cost /m2 Re: Single story floorplan 18m (w) x 12m (d) 9Dec 20, 2015 1:45 pm Build thread viewtopic.php?f=31&t=81011 2 6425 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8478 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4088 |
