Browse Forums General Discussion 1 Nov 25, 2015 8:12 pm Hi - I live in a brick home around 30 years old with wooden floors which is built on a slope (so the back living area is up above the ground). Normally I don't have many people in the house at once but this Christmas the family is coming over for a while on Christmas day to collect gifts. There will be 12-15 adults and 5 children, and I may be paranoid but I was concerned at having that many people on the back living area wooden floor and wanted to confirm what kind of typical load bearing such a floor could safely hold. As far as I know the floors are hardwood and the piers underneath are brick. Would I have any reason to be concerned or am I just being an old paranoid (: Re: Weight on a wooden floor 2Nov 26, 2015 7:54 am If your house was built to regs with the appropriate brick pier/bearer/joist sizing and spacing you won't have any problems. We've crammed 40 people into a couple of rooms and had no issues apart from a few creaks as the floor took all the weight. Stewie Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9156 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16565 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
