Installing new plates for powerpoints?
I want some with USB outlets and most with 2-4 outlets, but is it that easy? Does the electrician have to do anything to the in-wall wiring and then put on the relevant plate?
Also, how difficult do you think it might be for extra power points to be installed in a level 1 apartment (there are 31 levels in total, we're the first one off the ground) on both internal and external cement / brick walls?
Thank you!
More likely what you are looking at is replacing the power points. This would be a simple job for an electrician, assuming the old and new ones are standard size. Extra power points is a lot more work, as the cabling has to be chased through.
So...if a new power point was installed, and say the old one had 1 outlet and the new one had say 2 outlets and 2 USB outlets, would that work? Or would the electrician have to do something inside the wall with the cabling?
4
Ask yourself if the insurance company will be aware of the Reno.
25/06/2023
Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I…
6/10/2023
Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many…
