Browse Forums General Discussion Re: 600mm eaves / window height 2Nov 18, 2015 11:17 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: 600mm eaves / window height 7Nov 20, 2015 5:11 pm It will most likely be a T or H steel lintel 200mm. Engineers love steel lintels. I'll ask if the engineer can specify a 300mm lvl. It will make installing the bi folds (and possible motorised blinds) easier as the top of the door frame needs support. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15583 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10827 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5835 |
