Browse Forums General Discussion Re: Brick Workmanship. 13Nov 14, 2015 2:15 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Brick Workmanship. 18May 21, 2016 9:04 pm dkidston I think in these images we are looking at efflorescence, salt leaching out of the brick after being washed or rain. This will happen for while particularly with this brick, this just need washed again ...and maybe again. No it's not efflorescence and it'll only make it worse if they are washed with hydrochloric again. It's calcium staining otherwise known as white staining. Some more info is here...[See page 14] http://thinkbrick.blob.core.windows.net/media/1409/manual-13-clay-masonry-cleaning-manual.pdf In most cases a failure to pre-wet the brickwork is the main cause of the problem as the dissolved mortar after the application of hydrochloric acid [HCl] was allowed to dry bach into the wall. That is why the white streaks are vertical, because it was running down the wall as it dried into the brickwork. http://www.pghbricks.com.au/~/media/pgh ... rsion.ashx dkidston Inconsistent lengths of brick I am surprised this would be greater the a few mm. Brickies do need to check the manufacturers notes on these as the are a little different to your standard brick. Speak with the manufacturer yourself if there is a real problem they will often com and inspect it for you. They are faced with these questions all the time. HACK architecture http://Www.hackarchitecture.com.au Austral state these bricks are rated as DW1, http://australbricks.com.au/techdatasheet/techinfo_report.php They have to meet the dimensional DW1 tolerances found in the Industry Reference Guide http://thinkbrick.blob.core.windows.net/media/1398/industry-reference-guide.pdf Section 1.4.2 Dimensions and Tolerances Length = 20 bricks end to end @230mm = 4600mm with an allowance of 90mm +/- Height = 20 bricks top to bottom @ 76mm = 1520mm with an allowance of 50mm +/- The pic of the cut [zipper] bricks looks like they were cut without using a brick saw. The cuts do not look vertical and they are not cut to the correct size. I imagine they were probably cut with an angle grinder. Good luck Being a builder is more than just having once held a hammer. It's about the trades you hire and ensuring that they give a result that meets the industry standard and the home owners expectations. Building Standards; Getting It Right! G’day everyone, I am reaching out to share my pre-lining building inspection report, hoping to gain insights from those who may have encountered similar instances of… 0 690 We have a new build and need to clean bricks around a newly constructed deck. Need advice about whether to clean bricks with acid prior to oiling the deck, or should we… 0 2581 2 8320 |
