Browse Forums General Discussion 1 Nov 07, 2015 9:16 am Hi all, I am currently building out in the Swan Valley on a block that has some clay in it (S class with C2 detail). I need to think about my storm water disposal. I do not think that soak wells are appropriate due to the clay content as the water won't leach away. I am thinking of an under flow system that uses tanks with a pipe at the bottom that runs off into the council pit at the front. Basically any water that comes in, should flow straight out, if there is heavy flow, then it will back up in the tanks and flow out in due course. I would be interested to know what other people in this situation have done. Thanks! Re: Storm Water Disposal 3Nov 11, 2015 10:14 am Your council should have some information on what is appropriate for your area, or if not the Water Corp might. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6841 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10462 |
