Browse Forums General Discussion 1 Nov 02, 2015 9:57 am Hi, I have recently purchased my first home. Its an old 1950's place with faux brick cladding all around the outside. I am aware that the house most likely contains asbestos so I don't plan to do any major works on the place as I don't think it would be worth it in the long run. I just want to make it livable and patch it up a bit so it will last me a while longer and it gets me started. The old brick cladding has gaps in it all round where moisture can seep in. I plan to fill the gaps and was wondering what would be best to use, is no more gaps enough or do I need a specialist product?. I also had an idea of covering all the faux brick with a render as a way of sealing it up, how viable would this option be? would I still need to go around sealing it before rendering anyway? any advice is appreciated, cheers Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12035 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11108 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 |
