Browse Forums General Discussion 1 Oct 21, 2015 7:12 am Hi all, Short story: House is a few month old. Couple of months ago we arranged a driveway and a concrete footing around the house. Yesterday found a crack at the edge. About one month ago an adjacent neighbor did some earthworks around their house and cut the land right by the boundary. Approx. 350-400mm deep. They did not put a retention wall (do they have to?). Attaching some photos. Damage is affecting part of the driveway closest to house. My question is: could the crack had happen because of poor concreting work or because of boundary land cut? Soil is extremely reactive, (Adelaide, class E-D). Who is responsible now and what to do next? Thanks. * Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ * Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ * Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Concrete path crack, who's fault? 2Oct 21, 2015 8:11 am megez My question is: could the crack had happen because of poor concreting work or because of boundary land cut? Soil is extremely reactive, (Adelaide, class E-D). Who is responsible now and what to do next? Hi Megez Did you get photos of the drive way being built? Particularly, the reinforcement mesh /rebar used? The cracking on Internal corners as shown is typical and generally requires re-entrant bars which helps to control cracking. At a guess without further information it would be difficult to blame next door entirely, although I suspect it may have a bearing?. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path crack, who's fault? 4Oct 21, 2015 8:24 am https://www.google.com.au/search?q=re-e ... Eebu-nM%3D If re-entrant bars aren't used then simply it is non-compliant, sorry, you will be hard pushed without photo evidence or equivalent. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete path crack, who's fault? 6Oct 22, 2015 6:54 am Unfortunately, there isn't much more you can do except wait and see if its gets worse or if further new cracking occurs, it is a case of determining why, how and who is responsible over time/events. I would also be advising the builder/owner next door that he is on notice. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9315 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12873 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6535 |
