Timber retaining walls need replacing
I stayed away from wood because it will rot (even treated hardwood). If I had to use wood for some reason I'd use steel posts so that at least you could slide the sleepers in/out as required if you had to.
checkout www.concretesleeperscanberrs.com.au for some ideas.
For speed and simplicity concrete sleepers win hands down, and a browse of the http://www.concretesleeperscanberra.com.au pages shows how many styles you can get.
Sorry I can't price up as it involved other works at the same time.
Ensure you install the right fill and drainage behind the wall.
Looks like you have choices in Perth . Some use vertical posts, others steel C or H beams. All seem to have DIY Installation info.
The sleepers are very heavy, depending on size, so it's best to use a machine for placing them.
http://www.wonderwalls.net.au
http://www.conwood.com.au
http://ezyretaining.com.au
maybe more around, that's just a quick google search perth concrete sleepers
1
looks ok to me, round logs retaining walls are better than sleeper walls, more even preservative treatment and stronger since they include the whole tree and not just part…
26/07/2023
5
Yes, get a builder, make sure he is experienced and a registered building practitioner
