Browse Forums General Discussion Re: Powerpoint On Island Bench 8Sep 16, 2015 6:03 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Powerpoint On Island Bench 9Sep 16, 2015 7:09 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Powerpoint On Island Bench 10Sep 20, 2015 3:16 am bashworth I saw a pop up power-tower last week in a new build in NZ which costs about $200 + installation. I would definitely go for one, or two, if I build again. (see http://www.anewhouse.com.au/2015/09/power-tower/) A lot depends on what you use the bench for. If it's for cooking, like chopping vegetables or rolling something in flour, a hole in the bench top is not a good thing, even a very small one. I once made a bench top of small tiles. It was not practical, the joints got dirty and I had to clean it a lot more, than if it was a complete flat surface. In case you use that bench only for having a light snack and you don't have young kids around, than it might be a good idea. Re: Powerpoint On Island Bench 12Sep 22, 2015 9:02 pm This is the tower (EVOline) from Lincoln Sentry. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (in the down position, top only showing this end of the bench) ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Powerpoint On Island Bench 13Sep 23, 2015 12:12 pm I have seen many of these type of units break in conference rooms due to people not supporting the top of the unit while plugging in power so the force cracks the plastic at the bottom and they slowly fall apart. Re: Powerpoint On Island Bench 15Sep 23, 2015 8:01 pm To me they look a bit gimmicky although they would of course serve a purpose. We were at an open for inspection about a year ago and a few days later i bumped into the owner. Amongst a few other questions I asked him was what was his experience of using one of these pop-up power towers? He said they were OK but with a few leads running off them to a kitchen whiz and a blender the whole schmick stone benchtop they had was downgraded somewhat. As anything there are pros and cons to something like this. Stewie DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 4648 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 8684 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 29208 |
