Browse Forums General Discussion 1 Sep 14, 2015 2:27 am I am currently building and am considering enclosing the whole alfresco area(4000 x 5200) with sliding doors as highlighted by the red arrow below. The alfresco area will be concreted and tiled. I am hoping to make that area part of the house and possibly another place to dine. 1) Has anyone done something similar before? 2) Anyone foresee any issues? 3) Can this be done easily post handover or should I get the builder to do it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Sliding doors around alfresco 2Sep 14, 2015 6:55 am I love the idea but have you thought about using external roller blinds? You can get them installed on tracks attached to the existing posts/house and can choose the shade cloth type fabric or clear or tinted plastic stuff. The tracks mean no gaps so it stays warm inside in winter and then just open it all up in summer for a breeze, put one side down if the sun is coming in, all sides down if you want to keep out the flies, etc, etc. So many combinations Re: Sliding doors around alfresco 3Sep 14, 2015 12:06 pm Your sliding doors will have a fixed segment, so you will lose some of the 'open' feel. If you do not have two open sides, then you should not use a conventional BBQ in the alfresco area. You'll need to purchase an indoor use BBQ. I'd go with roller blinds as mentioned before. Re: Sliding doors around alfresco 4Sep 14, 2015 12:18 pm Bjhf I love the idea but have you thought about using external roller blinds? You can get them installed on tracks attached to the existing posts/house and can choose the shade cloth type fabric or clear or tinted plastic stuff. The tracks mean no gaps so it stays warm inside in winter and then just open it all up in summer for a breeze, put one side down if the sun is coming in, all sides down if you want to keep out the flies, etc, etc. So many combinations Are there totally no gaps at all so the air conditioning/heater will not escape? Also, would that keep rodents out since I would probably keep them close most of the time. Don't really like the idea of rodents having a party around the BBQ area at night... =) Re: Sliding doors around alfresco 5Sep 14, 2015 12:20 pm andre b Your sliding doors will have a fixed segment, so you will lose some of the 'open' feel. If you do not have two open sides, then you should not use a conventional BBQ in the alfresco area. You'll need to purchase an indoor use BBQ. I'd go with roller blinds as mentioned before. Not sure what you mean by indoor use BBQ. In the future, we will most probably have an outdoor kitchen/BBQ area with a rangehood. Re: Sliding doors around alfresco 7Sep 15, 2015 12:32 am Bjhf That does look good. However, would it be a bit troublesome to keep lifting it up and down to get in and out of the alfresco to the yard? Re: Sliding doors around alfresco 8Sep 15, 2015 8:41 am i have used aluminum shutters. installed after build i found this a better solution for me rather then the roll up blinds and cost way was not much difference Re: Sliding doors around alfresco 9Sep 15, 2015 12:56 pm 1rocky i have used aluminum shutters. installed after build i found this a better solution for me rather then the roll up blinds and cost way was not much difference Can you please post some pictures of how it looks like? we have a standard size and often we have a lot of variety to choose 0 3575 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5039 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 |
