Browse Forums General Discussion 1 Sep 10, 2015 2:44 pm Hi All, we are moving to our new home tomorrow and so excited to do some renovations and additions. First stop, where is the best place to install a built in wardrobes in these rooms? The room next to the bathroom with be a one year old boy's bedroom and the other will be guest/computer room. Not looking into massive built in's. Can't figure out how to add photo of the plan here.. Re: Built in Robes Locations 2Nov 27, 2015 11:44 pm Not easy without a plan sandds, that's for sure, but here goes. First work out the furniture sizes you want to install. Draw a plan of the room(s) showing the door swing. (I suggest 1:50 scale). Draw furniture sizes to same scale and cut out the furniture shapes and arrange on the plan. Allow 600mm including wall for the depth of the robes (unless walk-in type). I suggest sliding doors if space is tight. Now you can design the rooms yourself...da-da! Good luck designer. Re: Built in Robes Locations 3Nov 28, 2015 8:14 am Quote: Can't figure out how to add photo of the plan here.. sandds 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line and copy it. 5) Paste that into your post here then hit the submit button. Stewie DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12745 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4193 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4897 |
