Browse Forums General Discussion 1 Sep 01, 2015 6:58 pm Hi Guys, I'm currently getting organized to lay the hardwood tongue and groove flooring in the attic bedroom. The exposed beams are visible from downstairs, so I didn't want to use the standard floor cramps that dig in to the floor joists. Just wondering if anyone knows of another system of cramping up the boards that doesn't destroy the visual aspect of the floor joists. Thanks. Eric Re: Advice on floor cramps 2Sep 02, 2015 8:58 am Hi Erickendall Try clamping some protective plywood around the floor joists then cramp over...it's a slow process but should work Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice on floor cramps 3Sep 02, 2015 7:04 pm Thanks for that. Yes I did think along those lines if I couldn't find another alternate method. I was also thinking of using a car bottle jack and spacing it to push against the roof beam. I'll have to get something happening tomorrow. Thanks again. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18331 |
