Browse Forums General Discussion 1 Nov 02, 2006 8:01 am My boyfriend and I have decided to Sand back and polish the timber flooring in his investment home ourselves (due to budget constraints). Some of the floors had linoleum bonded to the floor and it's a nightmare to get off.
Can any one advise us on where to start what to do and what the best products are? Any help would be greatly appreciated. Re: sanding & polishing timber flooring ourselves...any advi 2Nov 04, 2006 6:28 pm You will have to hire a floor sander and edge sander. You really need to try and get any adhesive off the floor first. You don't want to be trying to remove it with the floor sander.
Try some acetone or thinners. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15909 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6191 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6467 |
