Browse Forums General Discussion 1 Aug 16, 2015 11:58 pm Hi guys, Im first time building house in Australia and not familiar with the techniques they use to build the house. In the plan, it said the house will be built on the "strip footing with base brick construction". does that mean they will plant many of the concrete pillars to lift the house up (my block is on the slope) and place a concrete slab on top of the strip footing? Regards, Thanks Re: Strip footing and base brick construction 2Aug 17, 2015 7:07 am chuminh Hi guys, Im first time building house in Australia and not familiar with the techniques they use to build the house. In the plan, it said the house will be built on the "strip footing with base brick construction". does that mean they will plant many of the concrete pillars to lift the house up (my block is on the slope) and place a concrete slab on top of the strip footing? Regards, Thanks It will be perimeter brickwork on strip footings and concrete stumps internally with timber floor over. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Strip footing and base brick construction 3Aug 17, 2015 7:44 am It will be like my build. I have some pictures on my thread if you want some visual assistance. Re: Strip footing and base brick construction 4Aug 17, 2015 4:08 pm building-expert chuminh Hi guys, Im first time building house in Australia and not familiar with the techniques they use to build the house. In the plan, it said the house will be built on the "strip footing with base brick construction". does that mean they will plant many of the concrete pillars to lift the house up (my block is on the slope) and place a concrete slab on top of the strip footing? Regards, Thanks It will be perimeter brickwork on strip footings and concrete stumps internally with timber floor over. Hmm, I thought they will put the concrete slab on top of the footing. As we laid tiles on our ground floor. could they do it with timber floor like you said. is that Australian standards. Thanks for your inputs Re: Strip footing and base brick construction 5Aug 17, 2015 4:09 pm Abztronic It will be like my build. I have some pictures on my thread if you want some visual assistance. did you take the real pictures of your builidng while it was being built? Re: Strip footing and base brick construction 6Aug 17, 2015 7:28 pm Well if you flick through the pictures in my thread. You will see that I have taken pictures of the strip footings and the base brickwork for the subfloor is where my build is up to at the moment. The floor has not being put in yet. Re: Strip footing and base brick construction 7Aug 17, 2015 10:10 pm And to Answer your question from before, The tiles go on top of the timber floor which will be on top of the elevated pillars. Most builders won't raise concrete off the ground like that. Its wayy too expensive and impractical for a house. Re: Strip footing and base brick construction 9Sep 04, 2015 10:53 am Mine will be the same I think, but a concrete slab slab still on top. We haven't started yet viewtopic.php?f=31&t=75739&p=1299716#p1299716 Re: Strip footing and base brick construction 10Sep 04, 2015 11:39 am You can check out my thread also if you wish. We have strip footing with subfloor brickwork and a concrete slab instead of timber/ particle board. I noticed you were asking about Bondek on another thread. We were going to use that also but changed to a different method called Ultrafloor. Ask them to price both up for comparison. Build thread: viewtopic.php?f=38&t=75302 Re: Strip footing and base brick construction 11Sep 04, 2015 12:30 pm My mistake chuminh. looks like a concrete slab on piers and strip footing is more common than I've been led to believe Re: Strip footing and base brick construction 12Sep 04, 2015 3:52 pm Abztronic My mistake chuminh. looks like a concrete slab on piers and strip footing is more common than I've been led to believe I don't think your mistaken Abztronic. I agree with most of what you first wrote. Most project builders won't consider it and it is expensive. It just looks more common to you because there is a few of us on here Build thread: viewtopic.php?f=38&t=75302 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18182 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10255 |
